Predicting Exponential Growth with SQL
SQL is great at grouping and counting the data you already have, and with a little help from regressions, SQL can help you project that data into the future.
Let’s estimate total users over time for a rapidly growing fictitious mobile app. The early days of this app were pretty messy, so we’ll chop them off add them in as the starting sum, only plotting dates after October 2013. Instead of a range join to get the rolling sum we’ll use a window function. To keep things organized we’ll put each step into a with query:
with
daily_new_users as (
  select created_at::date dt, count(1) daily_ct
  from users where created_at > '2013-10-01' group by 1),
daily_user_volume as (
    dt,
    dt - '2013-10-01' as dt_id, -- integer version of date
    84066 -- users before October 2013
      + sum(daily_ct) over (
        order by dt
        rows between unbounded preceding and current row
      as user_ct
  from daily_new_users
select dt, daily_ct from daily_new_users;
select dt, user_ct from daily_user_volume
Here are the two curves:
The daily_user_volume data has the look of an exponential growth curve, making it an ideal candidate for an exponential projection.
Linearizing Exponential Data
The easiest kind of regression is a linear regression. Of course, fitting a line to exponential data would yield a terrible fit. Instead, we can linearize the exponential data by taking the log of the data, fit that to a linear regression, and then inverse process on the future data points to get the predicted future growth.
The log’ed version of daily_user_volume is quite linear, so this will be a great fit:
To make a linear regression, we need to find the best estimates for A and B (intercept and slope) that minimize the error in this formula:
We’ll use the Ordinary Least Squares method for minimizing error of our estimates, which lets us solve for A and B like this:
Solving for B first, we’ll define estimate_b as:
with
estimate_b as (
  select sum(covar.s) / sum(var.s) b
  from (
    select (
      dt_id - avg(dt_id::float8) over ()) * (
        log(user_ct) - avg(log(user_ct)) over ()
      ) as
      from daily_user_volume) covar
    join (
      select pow(dt_id - avg(dt_id::float8) over (), 2) as
    ) var
    on true
Critically, we’re taking the log of user_ct to linearize those exponential data points!
Our window functions use over () so that the window is applied to the whole result set. It’s very convenient in situations like this, where you want to compare each row to an aggregation over every row.
Getting estimate_a is more straightforward:
with
estimate_a as (
    avg(log(user_ct)) - avg(dt_id::float) *
      (select b from estimate_b) a
Now that we have our A and B for the regression, it’s time to project forward.
Projecting and De-linearizing
With the estimates computed, we can simply generate the y-values for the current and future dates and then invert the logarithm! We’ll generate a series of dates that will start with and then exceed the dt in daily_user_volume, use them as x-values to predict the log(y), and invert the logarithm with pow.
with
predictions as (
  '2013-10-01'::date + i,
  coalesce(user_ct, 7111884) as user_ct, -- last real count
  pow(10, (select a from estimate_a) + (
    ) * i) estimate
  -- make more dt_ids for the projection
  generate_series(1, 275, 1) i
    left join daily_user_volume
      on i = daily_user_volume.dt_id
select * from predictions
Look at that beautiful fit! We’ve fit an exponential curve to our cumulative user counts so that we can project the counts into the future.
Here’s the full SQL for all the steps together:
with
    dt,
        order by dt
      ) as user_ct
estimate_b as (
  from (
    select (
      ) as
  ) covar
  join (
  ) var
  on true
estimate_a as (
    avg(log(user_ct)) - avg(dt_id::float) * (
    ) a
predictions as (
      select b from estimate_b) * i
    ) estimate
