CASE WHEN Statements
This post was originally published on the Periscope Data Community. To see more content like this and to communicate with data experts like you, join the community.
Overview
CASE WHEN statements provide great flexibility when dealing with buckets of results or when you need to find a way to filter out certain results. You can think of these almost as IF-THEN statements similar to other coding languages. Below you'll learn the proper syntax, where these can be placed in your query and a few examples that should help get you started. 😊
Standard Syntax
When using a CASE WHEN statement, it's important to remember you need a condition, what to do when that condition is met, and an END clause. A simple example is below:
CASE
 WHEN  condition
   THEN result
 ELSE other_result
END
More often than not, you'll want multiple buckets, or have multiple conditions for your data! To add these, include more WHEN and THEN statements.
CASE
 WHEN  condition
   THEN result
 WHEN  condition_2
   THEN result_2
 ELSE other_result
END
Reminder: Remember to include one (and only one!) ELSE clause followed by your END statement.
Organization
So where can these CASE WHEN statements be placed? Almost, anywhere!
If you'd like to change some results in a column to different values, this can be done in the select statement. In this example, let's say North and South Dakota put aside their differences and became one Dakota. You could update the results of your state column with a CASE WHEN statement!
SELECT
 CASE
   WHEN state = 'North Dakota'
     THEN 'Dakota'
   WHEN state = 'South Dakota'
     THEN 'Dakota'
   ELSE state
 END
If you'd like to filter out specific results, but you have to depend on another value to know which results to filter, a CASE WHEN statement could be helpful in your WHERE clause! A great example of this can be found when using multiple filters in one query.
SELECT *
FROM table
WHERE
CASE
 WHEN 'default' IN ('[name_filter|default]')
   THEN [id_column=id_filter]
 WHEN 'default' IN ('[id_filter|default]')
   THEN [name_column=name_filter]
 ELSE [id_column=id_filter] OR [name_column=name_filter]
END
A full explanation of the above can be found here: filters-in-case-when-statements
Finally, CASE WHEN statements can be used to help you order rows in the proper way. Let's say in your state's data there are rows that have blank values for states! You can still order those in another way, for instance by city name.
SELECT *
FROM table
ORDER BY
(CASE
   WHEN state IS null
     THEN city
   ELSE state
END)
The above should help you get up and running with the CASE WHEN statement in no time! Which is your favorite way to use the CASE statement? Any creative use cases for this function? Post your thoughts below! 😊
Skip Reagor
Skip Reagor is currently a Sales Engineer at Periscope Data by Sisense. A (Tampa) Bay area native, Skip enjoys watching scary movies and is always on the hunt for the next best burrito spot.
