Calculating Trimmed Means (SQL and Python Variations)
This post was originally published on the Periscope Data Community. To see more content like this and to communicate with data experts like you, join the community.
Data can often have extreme outliers, which can heavily skew certain metrics, such as the mean. One way to get around this is to use a trimmed mean. Using a trimmed mean, users will remove the top and bottom x percent of their data and take the average of the result.
We see trimmed ranges as a standard methodology that college programs use to communicate the standardized test scores of their admitted students (ex: 25th to 75th percentile of SAT scores). This is the same thought process that drives some data professionals to use trimmed means.
For the examples below, let's assume we have the following data: user_ids, and how much money they spent on a fictional gaming app.
Note: There are a few nuances to keep in mind when developing a protocol for trimmed means. Primarily, we need to assess how to handle multiple occurrences of a value when it is either the lower or upper bound of results to be trimmed.Case 1: Exclude upper and lower bounds of the trimmed dataset
You can perform this calculation in Redshift SQL or Python
Redshift SQL (assume the table above is stored in t1)
with t2 as (select
     case
       when amt_paid <= PERCENTILE_DISC(0.1) WITHIN group(order by amt_paid) over()
         then null
       when amt_paid >= PERCENTILE_DISC(1-0.1) WITHIN group(order by amt_paid) over()
         then null
       else amt_paid end as trimmed_vals
   t1)
 select avg(trimmed_vals) from t2
Python 3.6 (assume the table in Figure 1 is stored in a dataframe df)
# SQL output is imported as a pandas dataframe variable called "df"
# Source:  https://stackoverflow.com/questions/19441730/trimmed-mean-with-percentage-limit-in-python
from scipy.stats import tmean, scoreatpercentile
import numpy as np
def trimmean(arr, percent):
   lower_limit = scoreatpercentile(arr, percent)
   upper_limit = scoreatpercentile(arr, 100-percent)
   return tmean(arr, limits=(lower_limit, upper_limit), inclusive=(False, False))
my_result = trimmean(df["amt_paid"].values,10)
Case 2: Disregard duplicate values of the upper/lower bounds
In other words, ensure that exactly x% of the lowest and x% of the highest values are removed from the dataset. If there are multiple records where the value is equal to the upper limit, discard enough copies such that the resulting sample size is 2*x% smaller than the initial sample size.
SQL
There is no known effective SQL equivalent for this behavior
Python 3.6
from scipy.stats import trim_mean
import numpy as np
my_result = trim_mean(df["amt_paid"].values, 0.1)
Case 3: Include upper and lower bounds of the trimmed dataset
Redshift SQL (assume the table in Figure 1 is stored in t1)
with t2 as (select
     case
       when amt_paid < PERCENTILE_DISC(0.1) WITHIN group(order by amt_paid) over()
         then null
       when amt_paid > PERCENTILE_DISC(1-0.1) WITHIN group(order by amt_paid) over()
         then null
   t1)
import numpy as np
   return tmean(arr, limits=(lower_limit, upper_limit), inclusive=(True, True))
Neha Kumar
Neha is passionate about creating powerful data visualizations, spreading awareness of analytics best practices and learning about the latest and greatest advancements in data science. She strives to leverage multiple programming languages for analyses that are more efficient and effective than current methodologies.
